NoMercy
(Edwin)
1
Hello,
i notice after the 14.05 LB update that the layers cut/engrave order give problems
it dosnt matter where i put my cut layer (red 02) on top or bottom from the layers in the previev it shows the cut first and then engrave.
are there people with same problem.
when i cut/past the layer object is works fine again.
NoMercy
(Edwin)
2
edit.
still doesn’t do the order right.
now it shows engrave despite the ;layer order.
Mooseuk
(David Rodgers)
3
Have you tried turning on ‘optimize cut path’ in the laser window then selecting ‘order by layer’
NoMercy
(Edwin)
4
hello ,
thank you, strange it was off. i always had it on.
can it be that its set off during the update perhaps.
now its working fine again
system
(system)
Closed
5
