Using the latest version I encounter a problem while using the “Advanced” settings. After setting up the “Cut Thru” settings (see attached) the CO2 laser performed as expected with the lead-in cut at the outside of my graphic/part. I let the program run to completion. “Start” ing the program a second time without changing anything, the lead-in was INSIDE my part. I did this several times taking notes so that I was sure that I wasn’t changing any of the cut parameters. Please look at this and let me know if you get a fix for this.
