LB crashes when uploading .lbart files
I’m sure it gets old but I am new with LB and having problems with loading the art files.
First, I am running a trial version and not sure if that is my issue or not.
I have the files downloaded to the folder per the given instructions. I open LB Art Library and click on LOAD. The folder opens and I can see all of the files. When I double click a file, nothing populates and after 10-15 seconds, LB shows a NOT RESPINDING error. I then have to close LB. I have not had any issues designing and running other files, even a rotary. Again, I am running LB 1.3.01 Trial Version.
Trial version is irrelevant to the problem.
What is the source of the .lbart file? I’m curious if it’s potentially corrupted or otherwise invalid.
Can you try creating a new .lbart file, unloading it, and loading it back to see if it works?
Thanks. Deleted and re-loaded one file at a time. that fixed it. one of 25 files was corrupt.
