Hello!
I was cleaning, moving things around while E2 was cutting (while connected through USB) and it got disconnected. Is there a way to pick up where I left off or find a close enough spot so I don’t lose hours of work? Thanks!
Hello!
Hi Julia - It depends on what you were doing. If you were running cuts, you should be able to select the vectors that didn’t cut and use the “Cut Selected Graphics” toggle in the laser window (below Start).
If it was a single image engraving, there’s not a way to start partway through, but you can change the image setting Angle to 180 degrees, and that will run it from top to bottom instead of bottom to top. Then when it gets to the point where it meets the existing engraving you can stop it.
