LB doen't seem to want to hook up with my 10w UV laser
Can’t seem to get my 10w UV to link up with LB!
I have the same brand Fiber and I had no problem hooking up to it.
Might have to disconnect the fiber… I don’t really know how it work but suggest you use the OS to ensure it’s seeing the device.
Plug only it into your USB and check the device manager in Windows to see if it sees it.
Looked in device manager, it does not see it, not there!
Try connecting the new machine with the known good cable from your other machine.
Just tried that, nothing!
Did you look under the tab named “Ports (COM & LPT)”?
Can you share more details about your two galvos?
Even when they are from the same brand, it’s possible that one is using an EZCAD controller and the other one a BSL one. - Both need a different Windows driver.
For the EZCAD drivers, follow these instructions for installation:
If you’re missing the BSL drivers, you should find them on the USB thumb drive that came with your laser.
