Just checked it is light burn i have just really dont understand it how do you adjust the depth of cuts and engraving?also what is the best settings to make a picture speed etc many thanks
Hi just wondering what setting yous use to engrave a photo speed etc cheers
No one can give you the settings for your laser and material, particularly since you haven’t told anyone what laser and material you are working with. You have asked this same question in different ways in multiple threads and have been given a couple answers in those other threads. Here is one more. You have to do your own experimenting.
You need to do some more basic research about how lasers work and how they are controlled. Maybe try a YouTube search about laser basics. There are many videos out there.
This might help a little but also only scratches the surface:
Hi thanks for your reply i understand that part just dont understand setting up the speed and the depth etc i want to make some nice pictures and names but dont know how to achieve good pictures with the speed cheers
You MUST find the right settings for your machine. FWIW, Image engraving is about the hardest thing you can do with a small diode laser. It will take some dedicated study to dial in your settings.
Your question is the equivalent of me asking you, “Why does my lawnmower not cut?” There are hundreds of potentially right answers to my problem - but without more specific information we would be guessing as to what the problem is. Your response is 100% different than your first question. When you move the goal post with every new bit of information it is very unlikely to find any good answers.
Have you done a material test?
Have you seen the video guides?
Have you done any engraving with the laser yet?
(358) Dial in Your Laser Settings With LightBurn’s Material Test - YouTube
Read along the following Lightburn docs:
