LB not connecting to new laser
I had a Creality Falcon Pro connected to LB. I just got an XTool D1 pro 10w. I cannot figure out how to connect the new laser to LB. This is my screen:
You need to go at the right side of the program and find devices. You need to click on devices.
Than you click on crate manually and set it up for a XTool D1 pro 10w.
Thanks, but I can’t figure out how to go to the right in the program.
Try turning off beginner mode, and see if that helps.
:smiley:
So, firstly you need to find window at the top of your screen and click on it and than find laser and also click on the laser, like on the picture.
And then the on the right side of you screen laser option will appear. Then you have to click on laser - devices like on the picture. Finally you have to click create manually and set it up for your XTool.
