What we are doing wrong? LB always start from the outside. Choose best starting point is also disable (just in case) and there is enough space for the lead.
For a shape with corners you will need to change the Set Shape Start Point to somewhere on the sides, not the corner. Otherwise there’s really no room for the cut to start.
Insert a new node on a side if required and then use Set Shape Start Point to specify the side node.
