Left/Right, Up/Down Jog Distances are Different
Hello all. Long time Lightburn user but after the last update I ran into a weird problem: My left and right, as well as my up and down, jog distances are different. For example, I have the jog distance set at 1". I can jog right 1" using the on screen arrows with no problem. However, jogging left only makes the laser move a few millimeters. Same thing with up and down. Up is fine (travels the correct 1") but down only travels a few millimeters. My GRBL setting all look correct. Thanks!
And if you first jog left 1" what happens when you then jog right?
You can run the file in the following link to check for mech issues:
Post back the output.
If found some read this:
Its weird, that when I am actually burning a project, everything works perfectly fine. Its just jogging where things are messed up. To answer your question, if I try to jog left, it only goes a few mm. But if I then jog right, the right jog works perfectly.
