Lens calibration - doesn't match pattern
I have a problem with the lens calibration. I use Lightburn 1.1.04. When I open the lens calibration wizard I first can select my camera. Then I select fisheye lens and click next. Then I see the following picture:
Pattern
When I click on capture nothing happens. I move the pattern a bit every direction but every time I click capture nothing happens.
The pattern are on a piece of paper in a size of 1/4 DIN A4. I also tried with pattern in a size of DIN A4 but it also wount work.
Can someone give me a suggestion?
Thanks
Your pattern looks like it may be too small. It also looks like it’s curled up on the right hand side and the top left corner.
This may be worth review:
