I’m running Lightburn on an older iMac and using a Gweike Cloud engraver/cutter.
I’ve been trying to calibrate the camera on my Gweike but it is taking hours. I have finally got 3 of the images/positions to a score of 1 or less, but the 4th will not get to a score of less than 15. I’ve tried moving the circles pattern card in 2mm increments and then clicked on the capture button 50 times in each new position. I usually get a pattern not found or a score of 8888
Any help is greatly appreciated. It seemed like the existing posts for lens calibration issues were all locked.
No it is not normal. It can normally be done in a few minutes. Something is wrong with your setup. I don’t know what it is off hand. maybe focus? Maybe lighting? I initially had some problems and my 2 solutions was what I gave you, change the dot size and make sure the full page was visible. After that it takes the time of moving the paper 9 times and clicking the button 18 times. I’ve never seen a score like 8888. I don’t think I even saw above 100 but I’m not sure.
Thanks, I really appreciate the suggestions! Maybe it’s the camera on the Gweike doesn’t focus well, lighting, MacOs compatibility issues? Will have to start over and see
