i have just purchased the key for GRBL and downloaded the latest software. when i go to lens calibration and start the capture button does nothing please help as i had this working in an older version.
current lighburn version 0.9.18 running on win10 64bit, lasergrbl
Please provide a bit more detail as to what you have tried and what the exact results are.
Here is what I see in the latest beta I am using. Are you saying the âCaptureâ button is grayed-out? Clicking this Capture button does nothing and nothing is reported back when you push it? (Note the message LightBurn provides, just below the Capture button when the pattern is not found.)
ok, so i have now tested this with the built in camera on my laptop, holding the test card towards my laptop camera works fine, seems the new software does not like my hd web cam thats mounted on my laser, however this used to work.
Only software â only the software has changed nothing else and used to work fine in version 8
any ideas would be apriciated as i only purchased this for the camera support
The âDefaultâ system gives us basically no control over the camera in Windows, other than being able to stream and capture, which is why I wrote the newer âCustomâ system.
The âDefaultâ system (on Windows) uses old tech in a limited way, and doesnât allow setting resolution, exposure, or anything else. The new system gives me much more control, but itâs much more sensitive to driver and video card compatibility issues, permission settings, and all the other things Windows is known for.
