Letters change size in the same word
Why do the “O” and the “D” change size when do this file. The design doesn’t show a difference but you go to the priview it shows it and the does it that way on the project. Omtech 2440 100 watt. Speed 150 power 10. It will burn that word but skip the d or o and come back and yhen put it in larger.
Have you tried a different font? What was the result?
I dont have any issues with other fonts doing similar work.
You have a Kerf Offset applied on that layer, which is why only the closed shapes are affected.
Thank you. That was it.
