I’ve been using LB for just over a year and recently having troubles with .CLB.
I have it on 2 pc’s. Dedicated to CO2 80 watt and a 50 watt JPT Fiber.
Both are having issues with cut library failing to assign or to save. NOT A TECH.
Reboots of LB or PC fails to resolve the issue. Nothing I can find in the forums. CLUELESS what to do.
I’m having a similar issue. Will not save new settings to library.
Please select a different directory when saving your Library.
If this isn’t available to you, you may have to run LightBurn as an Admin to allow it to save the library to the protected directory anyway. ![]()
