Hello. I keep all my files in OneDrive now and I’ve changed the path in the prefs.ini file a few times and it does not seem to “stick”. I have to click on this 4 times every time I open LB. Any suggestions?
That file path looks corrupted. Did you change it manually? I suspect the format is incorrect.
Can you post the portion of the prefs file where you’re changing this?
I figured it out. Path was in 2 locations in the ini file. “Path” and “Last opened path”.
cheers
