Library not loading
Everytime I startup Lighjtburn, my Library window does not show up, I have to manually go into the Window menu and select it. Not a real big deal but with prior versions I never had this issue.
Try resetting your window layout and then configure your windows as you like to see if that resolves it.
Windows->Reset to default layout.
Thanks, I’ll give that a try…
