Lighburn latest 1.7 won't start on PC
Hello all! Recently upgraded to 1.7 which was working fine - today Windows 11 did an update and Lightburn would no longer start. Tried rebooting, reinstalling both Lightburn and redistributable stuff with no luck.
Event viewer:
Faulting application name: LightBurn.exe, version: 0.0.0.0, time stamp: 0x671a49b1
Faulting module name: MSVCP140.dll, version: 14.13.26020.0, time stamp: 0x5a39fef7
Exception code: 0xc0000005
Fault offset: 0x000000000001b93c
Faulting process id: 0x0x21C8
Faulting application start time: 0x0x1DB32206C15B926
Faulting application path: C:\Program Files\LightBurn\LightBurn.exe
Faulting module path: C:\WINDOWS\SYSTEM32\MSVCP140.dll
Report Id: d669845c-5afc-4fc4-87ea-7e4f19d2c3a1
Downgraded to Lightburn 1.6 and all working again.
Any ideas?
Thanks
Andy
I’d suggest you try fully uninstalling LightBurn and any 14.x C++ redistributables. Then installing the latest LightBurn.
I’m having the same hang problem. Uninstall/reinstall of C++ and LB isn’t working.
It’s a 64-bit Windows 11 that just upgraded itself to 24H2.
I’m involuntarily offline until this problem is resolved.
Did you ever solve this? I am getting the same error now as well, and Lightburn crashes before a loading screen is even seen.
Faulting module name: MSVCP140.dll, version: 14.29.30133.0, time stamp: 0x60ff28cc
Fault offset: 0x0000000000013020
Faulting process id: 0x5488
Faulting application start time: 0x1DB4C2EEA7C594D
Report Id: 1ceffa14-d327-40a1-94e2-3f32dd63e619
This was also after the latest Win 11 update.
Install/reinstall of C++ redistributable(s) did nothing, Uninstall/reinstall of LB also did nothing. Attempted a DiSM regresh/rebuild followed by an SFC /scannow, no corrupt system files. Please report back if you found a solution?
I’m encountering the exact same issue. Windows update - restart - Lightburn will no longer start.
