Lighburn LineStyles
I have an oval cork trivet that I have some graphics & text on it, I would like to add a frame just inside of the cork trivet. At the moment I have a simple line created using the Offset shape, I would like to change this to a fancy loop/flower etc to give the trivet more of a pop.
Regards
Howard
You could try some of the clipart sites such as this one:
You can also use ‘Copy Along Path’ to create borders etc.
Hope this helps
Thanks, I was wondering if that would work using the copy function, I just didn’t know where to start.
Many Thanks
As @Marcus_Wakefield shows, we offer several ways to do the things. :slight_smile: Below, I show another…
LightBurn also provides Array tools to assist in creating sets or copies of other shapes. In this case, I used the ‘Circle Array’ tool to copy 2 different flower shapes into an array in a circle.
