Lightburn Pro Version 2.1.01
Omtech 100 w co2 laser
I am attempting to adjust the brightness of the laser while I am framing. I know that you can do this with lightburn core. Is there a way to do this with lightburn pro?
Because the beam from a CO₂ laser is invisible, the only way you could see the frame is by burning a line into the material, which is probably not what you want. As a result, LightBurn does not provide any way to set the power of a CO₂ laser during framing.
The machine should have a red-dot pointer (or something similar) to indicate the location of the focused spot, which will show you the outline as it travels around the frame.
