I have been trying to use the rotary kit with lightburn i did all the settings as found on videos. I can do the same design on a flat piece of glass but will not do with the rotary kit
Here’s some instructions on how to set up a Rotary for engraving. You don’t say what machine you have or what chuck you are using so these are general instruction. You can skip the part about connecting the rotary because this is for my Atomstack machine and yours are probably different.
This is a word document so download the document then remove the .txt at the end of the file name.
HOW TO CUT MUGS WITH YOUR ROTARY CHUCK.txt (405.4 KB)
and add .docx to it.
