Lightbulb Bridge not discoverable
My light burn bridge is not discoverable on the Wi-Fi network. Any suggestions?
The LightBurn Bridge is pre-configured to connect to a laser configured with an IP address of 10.0.3.3. In the Ruida control panel, set the IP of your laser to this value, then connect a network cable from the controller to the Raspberry Pi, and plug in the Pi with its power adapter. If you need to change the IP address
I can see the bridge without the laser being powered up…
You should be able to see it on your network…
I use arp-scan that you can install on your machine, unless you have some other way to looking.
good to know… is the wifi setup still configurable from raspi-config ? SSH into raspian ?
