I have got a problem with LightBurn 0.9.16 under ubuntu 18.
LightBurn is working well but I was not able to communicate with My Ortur Laser Master 2
I added manualy a new printer.
I saw that the Port is recognized and named
but I was not able to communicate with laser printer,
On the console displays :
"Waiting connexion "
lsusb :
<Bus 003 Device 004: ID 0483:5740 STMicroelectronics STM32F407>
demsg :
[ 2653.154680] usb 3-2: USB disconnect, device number 3
[ 2663.260130] usb 3-2: new full-speed USB device number 4 using xhci_hcd
[ 2663.409237] usb 3-2: New USB device found, idVendor=0483, idProduct=5740
[ 2663.409241] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2663.409243] usb 3-2: Product: STM32F103C8T6
[ 2663.409244] usb 3-2: Manufacturer: tomeko net
[ 2663.409246] usb 3-2: SerialNumber: 5D7A154D36
What should I do ?
Is there special driver to install for orthur Laser Master 2 ?
Shouldn’t need any special drivers that I know of, but it might be a permissions issue.
Have you been able to connect to the machine through any other software or is this your first attempt?
Can you run the following commands and send the results back?
groups
This should output a list of groups your user is in, dialout needs to be one of them
ls -al /dev/tty*
Checking the permissions on serial devices. Please make sure the laser is connected when you run this.
Vendor ID and Product ID are same for me too, May be I should have a different value for group?
I tried my username specifically from **groups** output. But still no luck.
Rather I found this if it provides any further info. cdc_acm 1-10:1.0: failed to set dtr/rts
I updated the 99-usb-serial.rules to add **ACTION=="add", KERNEL=="ttyACM[0-9]*", ATTRS{idVendor}=="0483", ATTRS{idProduct}=="5740", MODE="0666"**
Now it shows that Laser is ready, Port is opened but waiting for response. Port opened, waiting for response.
