Environment:
LightBurn 0.9.19, built Sat 2020-11-21 @ 14:19
Linux Mint 19.3 Tricia base: Ubuntu 18.04 bionic
Fresh install of both OS, and Lightburn
Emblaser Core laser cutter
1: “Fire Button (‘Move’ tab)”
When the Fire Button is pressed, I only get ONE MOVE before the laser locks up. I have found that right-clicking on Devices allows me another one move before it locks up again. The one move can be in any direction, and with or without the ctl or shift modifiers.
Previous version allowed me to Fire the laser, then move it around while showing. Now I have to Fire, un-Fire, estimate move, Fire, check laser position, un-Fire, guess move again - repeat.
2: Push to Front and Push to Back do not seem to do anything.
Previous version clearly showed different overlappings as the ordering was changed.
3: Create Grid Array- X Column and Y Rows only allow typed entry of 2 digits (i.e. maximum of 99), whereas using the up arrow control allows far greater values.
To enter, say, 200, requires typing 99, then over 100 clicks of the little up arrow.
4: Infrequently, deleting the initial node of a curve makes Lightburn crash
5: Infrequently, resizing rectangles seems to cause the (0,0) origin to be included in the shape somehow, as the bounding rectangle becomes much larger than the shape, and extends to the origin.
