MacOS 11.2.1 (updated after the crashs started)
Lightburn Version 0.9.20 (tried with 0.9.19, same result).
No Laser attached, its a PC for preparing the files.
I suspect that you are running in a different language and have not set up a device yet. If so, this has already been found and fixed. For the moment, if you switch your language to English it should start up. Then you can configure a machine, and then switch your language back to your preference.
The problem is that the language settings are applied on startup, and if you haven’t configured a laser, there was a bug in the code that applies the new language to the interface, trying to set the text on part of it that is not created until after you have a laser set up.
I already set up a laser before (it worked for weeks on that machine).
Today, I did as you told - set the language to english and tried (after reboot), but with no success. Same crash as before
