Lightburn 1.2.00 Tabs and Bridges
Hi im pretty new to lasering. Im trying to use the Tabs function . When the Tab / Bridges are turned on in the cut settings editor and have inserted tabs in the project . And save the file the next time I open the project the Tab / Bridges are turned off.
I have tried
… cut settings editor make default (and all)
… saved file before closing
but as soon as I close the project or close lightburn next time i open it up its of again.
Any Help would be great
Cheers
Lee
SO- I thought I must be doing something inconsistent, I see there is someone else noticing the same situation!
Same problem here, I tried saving it, keeps reverting to no tabs when re-loading the file, and a nightmare when I forget not to switch them on before every job. Going back to old version till this issue is sorted, wasting time and wood with this.
Does anyone from LightBurn read these messages on here or do you have to report a problem to them ?
Lee
Not certain but the issue may be addressed with this post in a different Topic:
Correct, this is the same issue.
We’re here and @adammhaile is one of the best!
