LightBurn 1.7.01 Patch Release
LightBurn version 1.7.01 is now available. 1.7.01 boldly goes where no patch has gone before, correcting a handful of strange new bugs. Read the full list of changes below.
Download LightBurn 1.7.01 here.
  • Bugfix: Shortcut issues in Spanish translations
  • Bugfix: Small group of users that had camera resolution issues
  • Bugfix: Main window was not correctly using comma and decimal point in all cases
  • Bugfix: Trim Tool math precision
  • Bugfix: Issue with creating temp files when saving to network (UNC) paths.
  • Bugfix: File open issue for Japanese translation
  • Bugfix: Variable text state was resetting to default on project load
  • Bugfix: Selection weirdness and memory leak in Flatten Image Crop
  • Bugfix: Wobble moves in fills were showing rapid moves as cutting moves in the preview
  • Bugfix: Copy along path, when open, needs to shorten the path by the starting offset
  • Bumped allowed object diameter for galvo rotary to 1 meter
  • Suppress “transfer failed” messages on DSP controllers when not actually needed
  • Increase size of “Notes” dialog
  • Update to MSVC Redistributable 14.40 to fix issue with v1.7.00 not loading for some people
  • Update Norwegian and Greek translations
