Lightburn 2.0.02 can't copy and paste
hi
i’m using Win 11. I have read such an question from the past and followed the instruction to check if “use system clipboard” is enabled - it is.
Then I pressed Win+v to check for the history of the clipboard. Also, that can duplicate an object or cut if I press Ctrl+c, or copy with the mouse - nothing appears in the clipboard history and nothing happens if I paste.
Then I switch to “use system clipboard” off and it works. But after a while, Lightburn crashes.
So does someone has an idea which is wrong that i can’t use the system clipboaed anymore?
thx for help
hape
Personally I don’t have a ton of experience with the system clipboard, I just use Ctrl+C and Ctrl+V, along with Ctrl+D for duplicate.
Is there an error message or other warning presented when LightBurn crashes? Typically there would be a crash log saved to your Desktop. If not, that could be a sign that LightBurn crashed due to running out of RAM.
hi
yes there is a log on the desktop (which i erased but easy to build it again). But i hoped that somebody knews how to activate the system clipboard or if i should open a problem rhru the developers.
thx for help
hape
hi
here is the log i got a lot:
Crash Log Stack Trace for LightBurn v2.0.02:
std::_Tree<std::_Tmap_traits<QByteArray,QArrayDataPointer * __ptr64,std::less,std::allocator<std::pair<QByteArray const ,QArrayDataPointer * __ptr64> >,0> >::_Find_lower_bound
QSVector::~QSVector
PathShape::vector deleting destructor' TextShape::vector deleting destructor’
Selection::Clear
MainWindow::CopySelection
MainWindow::qt_static_metacall
MainWindow::qt_metacall
QMetaObject::metacall
QObject::qt_static_metacall
QMetaObject::activate
QAction::activate
QAction::event
QApplicationPrivate::notify_helper
QApplication::notify
QCoreApplication::notifyInternal2
Undo Stack:
Select objects
Clear selection
Select object
Delete selection
Select objects
Delete selection
Select objects
Clear selection
Select object
Clear selection
Move selection
Paste selection
Redo Stack:
Support Data:
AABEi3icvTxrb+O4rn8lyKd7Ltqu30kKLHD7StvdvtB0Ou0sFoXiKIm3jhXIdtvsYv77ISXZlh271UwXt8DM2CRFUhRFkaI7//SneRTP+vv/yIenJUmX/f1+aE3njm31dxQ426wpgG9pTElKATwjGQLGPOo5luPvWoNde9j7v54d7PsDwL+QOJpF2eZJEV6ypCS0BpLQ9ZCQ8jRiCZA4e9ae5fS/7/TjKKQJiAGtwuXzcTSf9/etnf4z3dyTGCiPxu7ItXeHh0eWb+96x9bBwfHuwDqw7OGuE7gHx+7uyHGtk6Bf8gI9Nml/3/btnX6akSyHl2Cnn5EFPPQXc10TG1RYczpPUYGD2V95mp2vFjcsfejv78J4HfTYAE2iv2mTDGEFXRwtkjMxG/F4D9Lw8RW0u6Nv2XG86O/PSZxSgCbhkvEzSSGeFXWSRWBdkkYJEGc8R9o8Y0dLGj6PGf+yRpunOmpCXuiEhiyZoQ0ckH7IWHxG47WclW35QQ0G6voDH0CbNUnTySbN6OoYpDI0l9LviKwoJ5dsRsfrVGgmITecvkT0VQCdPb8A3zIwOx1Z1XiaZJSfr9aMZ3Q2WZI11ZjDuj1PaHzHYhibhOAMLkBZzLhkdw8iiikesdWaZF8JT8AkZ9KD+whOMs7iS/ZCz5OQ0xUIlHrm2UWUwvMf//SjZEbfxIKsyNsNe6W8vz/U3hyYBLwmIBQ9z8I9keSrGzALquvs9HmeHMZyoFI+XVM6U/41PWK5Elu8XJK34n2yJqFYRh9837PgZ2T7vjNwPQ/wctOBtrApSk1tXVPvHU3t/ju62Zb172g3CUmiq+fo6qELdannvKee+6F27dLd2jK+I93ta6bYZjdjWTl5QCvuHj6Bz75gFAKT+Jb8GXi+5Q+tQBfubq/MKkoUUtcEgyB4KA9hmYGpp3j6o8DyAs9/z0jungs/lu17nj0cIa2JzRr+5JuazNdM5nSuQGDKLqjY/ZziA1NJA03xbscdmrIbauz8TnYjU3YjjV3Qyc62DPmJQ1vxG3bGENuUm11xG3Vyc0y5Oa27rsmutomd7ghn65u4001wyc2081odvMnOdL/Y+n5xO9mZ7hc7aPXiJjvTTWEPWr24yc50U9jDVi9ushuZrqy+KaxOT3EsQ36OZcbPNuVnm/FzTPk5ZvxMd4bjmvHzTPl5Zvx8U36+Gb/AlF9gxq+2OwRhF0N9e9h7QRAMLMsNXNsf4Z74idPKGZrOZWg2F9O95Hywl6BKW1KOaTwA5QuQ7rQmxoMPEmPz5FLqcL4iC7qtRZrl4XNU6WC6La2ObdkhZnuypgeZpe3X4efmuq3Ez+SwpvmyocFN44LVERcMxZiGC6sjXBiKMY0iVkcUMRQzMBUz+JQY0zhidcQRQzGm4cXqCC+mW9v0CLc7jnBTOaYxxP6xGLIlx/TItzuOfFM5P5Uk/4ScWigI3pHj/WshcUsH0zhhfy5O2KaBwv5coLBNI4X9uUhhm4YK+3Oh4tNpvaGcT6f7pnI+WwaYyvlseWAq57Nlg6mcz5YTpnI+W2aYyvls+WEqxzQeOJ+LB58uQUzlfLY0UXL+FDf11zxaRIkoRI4fxqLRETNsDll7ljWSP4NB4A0df+iUNMc0o2H2JYmyshECmJM3bDYc8FAHKiLkT/jzIQmfFxwOq1l53XpM5ySPM9BlQrNM3Am39w26p9rHjlLEeJRtxJjOeqwQdkxfImx6YNNIgcYsyc5otFhmcgto4Csp5YBHJO6XGGw9/X8oHIOtD+YZ5XecoM6l2XAKZaNFtKdi8dbv60ZVFH+WsDvG4jo8Stcx2ahZnt4eXgCDk4RMY3pBUlD9ej5PaVZKlqgbzkKapg3c6ZfzY2BC/z5xr1Yn9tUKWBVW9XB2Z2xFr5NJRniWrws3OU/mTOr9G1tgXylKcpZX7SpdjQdhMB3yWEAy2buSnKr3q9LmCAO7XURTTvjmhmTYyvq2/4vg9stBRv/mu471dS+Mp0B9SULOUmmjy4hzxh9KjeT7Y/XOXijoDqbMZDsNM28FHHO2KraZnK9CTLRVV6BvrRy+lZQ7/foy3bA0yiKW3EUwU7kwhZDaAkmr1UCPBWgewWpKWyiutxS7tfRcdWOwAUiTlGSif6tmrHxfdnEjfpCmoPnloOqvdvRiY/ZaDB3TLFyWAw5JPrsV7Wzb9h20iebTH/QtV6sbiDy4a64vbdWblD405sJexfh6wGPADNumTwc8O+TsNdW6QBWy8KptBEtSVhlcQ+D2Ej62jRO+NgaTpy0cC5drDkI/2IaKpi4s4JryLGrld08gZoFPYPO7sX8PMQinwsQFZ4k4vrttkJ7yafwbGploYVuivjTev2nvs9MjeYLBgowZD+nknsQ5vc6zda5FDCQ6ivMUfE3E0gLOI+xaIwMHUx/xnpC1cKPiRQqdFRMQ4KKxaBdhYhxx+lTfGxW8ahlKGLpLSaxUuaIL8P0X+pXx53StB+ECU037+vKOhssbFpPKla6nfynNrfKlofn1OotW0d8ao1saS9bXSVy60eRpEpJYBAfcIPjhATb++QZccR5VxptEK/BOnsChUe2U9hMdSccQF78uo4yKvlghq4kogpBEncZsSuIxCTPGSyBUoAdhSOMHvDMTGmrAxwZQ8HvA9ncD9qjOCgGLEjmRuvRbssalFqCSFpXcFl9Ca/LFWF3752gtZjqOSfndRwnUhOPJpTn2JF9j0lOccbjCk1eyfnhsuPkdmd7k8PQ1mmGkbW1vwwGfpPMi8QNOVe70JaWnFmyiawzMYpEUX0BA0FhGCT1ijM+iRH6cUmHBzZMoXT4UbNS7jP7YGX/lOGsISIcblSGo4ZB9YK5Q7ZA71TylKhFSc/Fs67tMI0LCZzDv67kMLsVHJypuyTRDz7MGNag8ls6Ob85ldJYYzYFtGdou4M95kqBSVUTECHmQnkJqudbBN2Q2Kz4zOOZkgWfHktN0yfCzLExo3+bni4TxthB5e3dRQsBAsF3lZzEFCHQekxfM4qhKExB0S0Oa4LJBVjaPxRdQVeL3e56kGUyoNwl5tJYtgi2ik9krGDIiiaLqnd8dtVPKlPS7kpyeRbMZTSpVUjgi4Lg9eyhMUgHv7sYlUMQ8URXIdatmKDHJLHqJZjmJq0AkMdJR7eIVlj6NZlQPWBKBbpRKsBbdDzgnm6dDmr1SmsjPldKHDykeWyiOOAW3v48gp8RvR7bwwi1uaQq+nepnhcTewrEmMjQQUM9xmjQTEQUsHQEOBZVQJ+8HlUq1sHyYLKN5drg5I/G8FS1PGrf4ZmXku8HAc/EaraJ67Ob/+D7/x5L/QPL3BsHQHRTsP330Cpt3fH52tl7ET3iElRC5B0VwPZ9fMoh7EOvmld6SkfTvg/MLsoFJV8gEbJBdQrZHvzG20sqGZJFjrQsFSaLSfzwJ1qDRyZeLA4Db+dntfDV5eaPx19fXycWZHZL7119/Lah5Vi8WFPyQcDwCnvAvGRX9YR1zAnmzxFh1xHkCx0IZ4XUM5AC2LEkbUKeN1N0CquxefZd3tCS8VkGVdGL7i2hXJkMlDhLGoqIraqrJfX3usspvFk/i7x4kvr+cxiTtBf7OoAcMeS9ltXHqDDmPMePjBJa5J5Lh3v/87x6J/qNo5XIrGeP9irvCty6KOgeL6qKOBOP8BRu1m6X8rlPlww5eIl8wMtPq6LrP4SF0AGV7mGkgllLxDeUlEYWNKvYaaolPQl1/OGxDYY4ycLcw6rtXD/uVLahH7B0IFMjFYCuUFapUGgNSHNzSdqJe+KOr+MWKl5I051Sq67mjQAehQFTziokt+zvdTBkcWWMW5mUQvMK8Pucp46ii8Kcrxlek+cWob5YgC6+UqaA8AiVE3o/Iog7mWeXcEgspfihDejWirLD9AlRk342cTSFzsFvt8JJwGfmbQxSnJ1HolsG5nuQ/QaZVKdYcebhRWQxGAg0q1lTOowLelLdIOvHRUrqiMlZTAnhzNa6hmriGw4lt1yZPEH4pXuDF4hvgJleRkt0xYa6toeKBxCcQmjY3LEqydgp4AAXSbSTYMSbrY3EXgN+xq+TZHTi+M7JcjfSWzvKQgn0hACYL2jJ9SQHJ9guNtyTd0hW4p5LXMhgy6MI+xU1CkwQqhnDZ8DzhJfVabDv/v8FEmEA0nBWVwETelBYXOuLLb3na0aoSV3AcreoUqwLKaOMFQx2EUWbklBBRTMmrF3HvosAiBQAXk/l/TQdxhKABeSo2XR0pg9UAP2PWQPjRuy/UEJEYa9f78ncCoN4lkPHGmJvEUH/jRxfYDtWhItSIyVXQZm5XFM8awVW+OmJrEe+GdYz8Zr5Ayjno+NbcTicAZxBZQipz05JEVADqjueP2mHzyySDpOwZ/Jj27mmU9Rx/L57yBFtQH9D1XGNKz5jStntQDWW93i78S2Yb84Huzw50TAam4ZKTfEqTHtRWmTlzy4T5cQRHBu8lNO85P6j9yJjSfF2D3u6PKeGY22PHXA27nfK3fL2Wplq2E9wzCJUL2qtYfmz1dooTrLFhyZ3e791sCiL7PSJdVofaOkn00dQbXnK+34X7E3c/Hi+XrHa6i0wADgAZUjD9Fy0dURdVt3ZnD1XSivERbyzOoPKMqbjOreIbIn9j0wu2aILkoXSDv191x1SordFIDUC3LhqBbxZu6j4MK8pG+oZdLTwODmLCVw7+glMVCBEuQ+MRZ6mmPsIZ5AtCkQuWZi3jNjH21CCL5eokvU4uiXbeIhFe8XwFMvaKDPTh4zyOoR5NZAZaGyQWuGic6GMu5C+zQaES8Sr9aWIg6Z6w5sAkfzu5vlC/I1VDgYaFGVvQNwTS1wxOkSmNUx0hr3VbpgzTdZ0mp2i1jqksKqsb4LVo0omztuhTKvKWO8uXxSiYraOS5GUh+rwV5G4JC66aT/I31noC1Fco5bmTx8ndyWVfXh0e5lnGEpn+O01QedFXb0j+05/Llo0Uu4y0SRWfcFYXYHfY7VEdU+Qjr8k+ZGBXDJwmgz/xIhaO+GNsiS5kGg4HfVEJimbQEVlnUAnp96wnb+DmUILgsS9/l0/HnsKpBANqN7NnYH5aNClvq12GKaYw8FEcrUVdVY6Svn6eXpI3kWs2MTLdc/zA1iDyqle+qtzMEZlYBXrET968cpCINmAQmaDO5ypTteYz9eBYHT/zsMTZ86l68CzLsyHRdTDZhWdHPgfAdzCAPy48+xJW8lE/6m1QQAreUgtHvnuBo8nFZ3lhNlR6SGrbd+U4GEZKQcWoUaGtBaMDT2rmgWYDX2o9UKO3tLPdClLMmMLYmZphIGfnIV+7PlsfZAQjKQ8/gQ+krHY5upULOUTqiHICqnjjcyh5/Rj/4bQ5DzROm95eoPgqOYjrkPXhipayAjUXkBXMKln4XpujV3kPyv8xudP5llyg9QM1R0fxQh0czY6e4juUvH9MZki2ZALExzkNlVxLybG0nWFVNkDeQt5P2ZpsybeGW/7Z4duOszU2VGPRRq6mb9f+sIhbQuTOhIpdLbnchza1pU6tO9MpJVNtZ257ZccMcJQ12PJqbWcLXiO54oXHCauPfnAH2VNai1ODgazxvaCYi9f4d1j8W8QsS1vFmhWU5yMn4Y3zageADdx2yzd/7KDi4jl1Lt1c5+R9rqWOhRahJqXwlJHYvR9GNqUn0TgUq6FWBmNAsRJFnFBxQZ0K7vTf4S78Yl7BzHS3Gmtt69ag0utq8W0k95HnKy8bfXDebP+EDd+oIpWyCB19wIE2VmyudPE1PQKXfmBXR+NSeBPuz2m5/mhHxW0YfKBT4U3KCvZQ467tXtxiYuWKs8hTdF0xTfuB1C+XLXb8TylSkXTh90yE4/V9/20YPAX4Ma38Xzqa0GfI9/AGsf8aJUlWAp6q/3PDtvasPQe165cJp8ywUrx5UddfPcc7wyyUpfpQ8fEzVFlQd4isWKZ2lvjkS2Z0Kpfzxf84UWRxYHjMYFVG+yqF9b9//y8PyUri
