Lightburn 2.0.02 won't enable rotary
I upgraded to version 2.0.01 yesterday. I tried to use my rotary (PiBurn Omni) today, but it is totally greyed out - will not enable at all. I upgraded to version 2.0.02 today, but it still will not enable the rotary. I have been using this rotary for years, used it 3 days ago. The only difference is the upgrade. What is the go with this?
Did you find a solution? I am trying to set my rotary up for the first time and it is giving me fits. Responds fine when controlling from the machine but when trying to operate it through lightburn, it does nothing. I’ve even done several troubleshooting suggestions from Chat GPT. I have this rotary: 4-Wheel Rotary for 50W and Up Laser Engravers – OMTech Laser and this laser: Maker 90W CO2 Laser Engraver and Cutter (MF2028-80) – OMTech Laser)
My rotary is working, but the rotary icon in Lightburn which normally has a green dot when the rotary is enabled doesn’t show the green dot. Good luck with setting up your rotary.
