Recently installed 2.0.04 and have configured for my new Xtool S1 20W. All ok except for one problem:
I have successfully adjusted the Y-axis offset as described by a number of set up videos. However, I have an offset on the X-axis - looks like about +4mm, but I cannot adjust it out in the device settings.
Framing the work piece is spot on, and the cross hairs go to exacly the center in X and Y using the move tool. The framing is also correct. However, if I place a test square in the centre and run it, the resulting cut is 4mm positive on the X-axis.
Any ideas?
I seemed to have solved this. Not entirely sure how. I went into XCS and updated the firmware(s), but also realised that having made offest adjustments I need to cut again before checking the framing. But anyway, all good. Cheers
