LightBurn 2.1.03 Patch Release
LightBurn version 2.1.03 is out now. This release contains a handful of bug fixes, listed below.
Download 2.1.03 here.
Bug Fixes
  • “Ask for sent filename” button was forcing window to be too wide
  • Added laser 1/2 selector to focus test
  • Changing device was marking project as modified
  • Allow CDM devices to load as Serial on MacOS
  • Added a new JCZ board signature for Aurora
  • Ensure each job run is logged for Galvo Rotary or SplitMark Jobs
  • Padding and Edge buffer were doubling the spacing
  • Prevent Bitmaps with invalid XFORM from crashing
  • Increased fire safety
  • Corner radius fixes
  • Image inside of shape could lock optimizer
  • Allow 1 decimal for pre-ignition value on Ruida
  • Fix for potential crash when switching units
  • Added 10% more wiggling to the wiggles
  • Material library thickness should have used Design Units
  • Bugfix for user origin if G54 is not 0,0
  • Warp and Deform weren’t retaining bitmap properties
  • Various camera fixes
  • Fix for Web Tools loader
  • Properly handle layer names with save to and loading from Material Library
  • Disallow setting one shape to be the mask for more than one image
