I updated yesterday to LightBurn 2.2.00 and suddenly everything is mirrored when burned. Never did that before.
Switched back to 2.1.04 and everything works again as it always has. I don’t see anyone else talking yet about this issue. Trying to figure out if this is a problem unique to me, or if I need to wait for the next update before trying again.
First, I don’t know why it happens that LB “loses” some settings in some cases when updating.
But as with all changes to your system, you should always make a “Bundle” with all the relevant settings from LB. This LightBurn internal automated process also makes it much easier/safer to, for example, move to another computer or OS.
You simply import all relevant data to the new (updated) machine again from this Bundle.
If your machine orientation/workshop orientation is lost/changed, it can also be changed manually, but most likely your measurement units are also wrong after updating, that’s what people most often complain about. (It can also be easily changed manually)
If everything works fine in your old setup that you have reverted to, then export and import the mentioned Bundle to 2.2.00 afterwards again and everything is fine.
I will have to look at “bundles”. Don’t think I ever noticed that setting before. Wish they called it import/export “settings” or something that makes more sense to me. “Bundles” just makes me think of firewood.
I ended up just deleting and reinstalling the drivers for the laser and that made everything happy. At least my workspace is now in the familiar orientation I always work with.
I thought I was going to have to flip everything backwards and upside down, which would annoy the heck out of me, as I got used to doing things a certain way.
“Import/Export Settings” might be a better name, I don’t know. I’m used to “Bundles” and use them regularly without thinking about the name.
Glad you got your problem resolved.
