Lightburn Adjusting image
Hello all!
I am using the adjust image for an image.
I click on Jarvis, negative image, and OK after entering all of my settings. When I click ok my image does not change to a negative image. It stays the same. How do I switch it over to a negative? I did try Imag-R for this file, but that was not giving me the results I am looking for.
THanks
Apparently the original image stays as is in the work area. But, if you go to preview and make sure “Invert” is off, you will see that the output is in fact inverted. Hope this explanation is clear.
Thanks Clark! Youve been a great help with many of my questions. Much appreciated.
