Lightburn and CNC3018 (GRBL)
Sorry, but a noob question. After I initially purchased Lightburn, I was able to do some engraving. I’m now back to do some more basic engraving, but the material isn’t getting cut. I have the CNC 3018 so I know there are some limitations. But I do have communication. I can move the laser and I know how to set the home point through the console. But for some reason now, nothing is engraving (wood or leather). Like there is no strength in the beam. The laser is 50mm from material and I zero in the beam. Nothing. I can go over to LaserGRBL and it burns no problem. Is there a setting I may have accidentally changed so that nothing burns using Lightburn? I’m out of ideas and I can’t find a solution in the forums.
This FAQ is a great place to start if you haven’t seen it already: Configuring a 3018 CNC for use with LightBurn
Thank you sir. My speed was too high.
Thanks. Fixed profile. Should display CNC3018
