I am assembling an XBaitu 20W M81 engraver/cutter. The LED vs CO2 settings in the configuration that switches from mm/minute to mm/sec seems to be important, but does it do anything except change the units?
Since 100mm/sec is the same as 6000mm/minute is it just a reference to how much slower diode lasers can operate or is there more going on that it appears under the covers?
The early GRBL / arduino set ups can max out in terms of clock-speed and steps per second. There’s also a minimum speed that one community member ran into.
GRBL is mm/minute in the firmware. Tell us more about your controller.
