Lightburn Art Library Housekeeping
I have found that I have either misspelled a name or need to change the letter to a Capital aftter thr Library has been created. Is there a way to Rename the Art Library file. If so I have missed it. On the same subject is1t possible to have more than one Art Library open so I can drag and drop for one to the other for house keeping of my files
Thank You in Advance
  1. Locate the art library file in Finder.
  2. In LightBurn, Unload the library.
  3. Rename the art library file in Finder
  4. In LightBurn, Load the library.
You can Load multiple library files. I don’t think you can directly drag or move art from one to the other. You will need to use the Workspace as an intermediary. So place art from one Library to the workspace. Then switch Library and place art onto new Library.
Thank You I will give that process a try
I just did what you instructed and it works very well. Thank You again
