Lightburn Bridge Connection Problems
Hi all,
I have two Lightburn Bridges connected to my two laser Machines. Both are in the garage and quite a distance away from the Router (Hence using the bridges). My Wifi provider was SY and for the last 4 years I’ve had no problems at all with connecting. Recently I transferred Wifi to Vfe and cannot begin to explain the issues I’ve had. My main issue for raising this here is I now find that I cannot send a file to my lasers that bigger than 1Mb which is problematic as the file I need to send is 1.6Mb. Each time I send it I get the following error…
“There was a problem sending data to the laser”. If I cut the file in half then it will send EVERY time but send the original 1.6mb file = same issue.
Naturally I’ve spoken to my new Network provider and explained to them that if the ONLY change that has been made is the network provision then surly that must be where the issue is? Their answer… NO it’s a problem with your equipment!!!
I’ve tried the usual trouble shooting… New File, Cleared files from controller, Rebooted everythning, checked for updates. Checked IP addressing and network config and everything looks fine.
The only way I can get it to work is to send one part then send the second part without removing the piece I’m working on which isnt ideal.
Any suggestions?
Great software by the way, I’m an avid user and have been for many years!
many thanks
John
