Hello everyone! Read about 10 topics with this problem - nothing helped me to solve my problem. I have message in LightBurn - No laser Connected. I got Raspberry 3b+, and Ruida 6445S controller. One router in room with one laptop on wifi and raspberry on it.
Logs
Nov 14 10:46:20 lightburnbridge python3[423]: 2023-11-14 10:46:20,013 | INFO - Running: nmcli c add type ethernet ifname eth0 con-name LBBDirect ip4 10.0.3.1/24
Nov 14 10:46:20 lightburnbridge python3[423]: 2023-11-14 10:46:20,119 | INFO - $> Connection ‘LBBDirect’ (19b285c1-d0e3-47a9-9c7d-15ee782d634d) successfully added.
Nov 14 10:46:20 lightburnbridge python3[423]: 2023-11-14 10:46:20,126 | INFO - Running: sudo nmcli con up LBBDirect
Nov 14 10:46:20 lightburnbridge sudo[836]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/nmcli con up LBBDirect
Nov 14 10:46:20 lightburnbridge sudo[836]: pam_unix(sudo:session): session opened for user root by (uid=0)
Nov 14 10:46:20 lightburnbridge python3[423]: 2023-11-14 10:46:20,387 | INFO - $> Connection successfully activated (D-Bus active path: /org/freedesktop/NetworkManager/ActiveConnection/7)
Nov 14 10:46:20 lightburnbridge sudo[836]: pam_unix(sudo:session): session closed for user root
Nov 14 10:46:20 lightburnbridge python3[423]: 2023-11-14 10:46:20,401 | INFO - Starting ruida relay
Nov 14 10:46:20 lightburnbridge python3[423]: 2023-11-14 10:46:20,403 | INFO - ruida 1.0
Nov 14 10:46:20 lightburnbridge python3[423]: 2023-11-14 10:46:20,405 | INFO - Ruida relay started, laser IP: 10.0.3.3
Nov 14 10:49:17 lightburnbridge python3[423]: 2023-11-14 10:49:17,583 | INFO - Connection from: 192.168.147.101:60655
Nov 14 10:49:17 lightburnbridge python3[423]: 2023-11-14 10:49:17,606 | INFO - Ruida command complete
Nov 14 10:49:17 lightburnbridge python3[423]: 2023-11-14 10:49:17,610 | INFO - Connection from: 192.168.147.101:60656
Nov 14 10:49:23 lightburnbridge python3[423]: 2023-11-14 10:49:23,761 | ERROR - Laser timeout error
Nov 14 10:49:23 lightburnbridge python3[423]: 2023-11-14 10:49:23,762 | INFO - Ruida command complete
What i did:
- Re-installed image on raspberry 3 times
- Tried 4 different ethernet cables (5, 5e, 6 CAT)
- Tried different IP addresses (just in case)
- Tried to connect from extension port and from ruida controller
What I cant check - if my controller fault. But its brand new. And I can connect and control it with computer<->controller direct ethernet connection from LightBurn.
One thing that bothers me - on my raspberry pi always lights only one green light (solid or blinking), so no orange light. But this raspberry was fully functional last time I used it (for my smart home system).
And I can’t check if it’s possible to ping controller from bridge because i don’t know credentials for SSH (tried - root/root root/admin admin/root and pi/root and all combinations).
Any ideas? ![]()
