Lightburn Bridge Raspberry Pi compatibility
Hi!
I want to buy a Raspberry Pi to connect my Ruida Laser wirelessly. I want to make sure my system is compatible:
OS: Windows 11 Pro
Lightburn version 1.3.01
Ruida controller: RDC - V26.01.13
And I want to figure out which Raspberry Pi to buy. Besides making sure it has a wifi antenna and an Ethernet port, is there anything else I should check? Which models does the Lightburn Bridge support? Only 3, 3b, 3b+, or 4? Will getting the newest version 5 work? Is there a minimum amount of RAM I should get it with?
Thank you.
I set it up with a Pi 4 with 2Gb of RAM and it is working great.
Hi @aletof
I’m pleased you worked it out. For anyone finding this later, the LightBurn Bridge officially supports the Raspberry Pi 3B, 3B+, and Raspberry Pi 4. Other Raspberry Pi models are not supported.
