LightBurn Bridge Setup for Mac to Ruida controller
Hello, I have the same problem. My computer (MacBook Pro running MacOS) is connected, but I can’t send files tot the laser. Because it’s occupied or paused. I’ve connected an ethernet HUB to my USB port en the laser sees the connection but I still can’t send files. Does anybody have another solution I can try?
  • Is this for a larger Ruida controlled Laser engraver?
  • If so, do you have either a Free trial or a ‘Pro’ license that offers DSP control for the Ruida controller?
  • Has this worked previously?
This is a common assertion but this problem does not seem to be the same as the one in the Neje 2s plus thread above. I’ll move it to the correct category after confirming information above.
I’ve solved the problem (actually a friend did). It had to do with the IP adress of my laptop and laser machine. Here’s how: Ethernet Connection (Ruida) - LightBurn Documentation
