I have a lightburn bridge, as of yesterday it was working great then all the sudden it stopped working and i couldn’t connect to my laser, it wasn’t popping in my wifi, and LB couldn’t find it. today i pulled the SD card and deleted “wifi.txt” plugged it in and was able to get it back on the network. it worked for about 10 mins, then same thing happened. really could use some help. I am using the latest LB update, my laser is a omtech 60 watt 2022 with very low hours, the bridge is less than a year old
Try a new SD card? They do not have infinite write capability.
Mine did the same thing yesturday. I have zero control to my laser, I spent all day yesterday trying to fix it
I’m having a connection problem. I can’t seem to connect my lazer to my laptop. I have an HP Laptop with Windows 11 home and I have a Creality Falcon 5w lazer engraver. My lazer isn’t connecting. Looking for some wisdom. Any insight is appreciated.
Thanks
I just started having the same issue a couple days ago as well. Following to see if anyone has a resolution.
