Lightburn camara
Hi I have just joined this forum. The question is will the laserburn camara work with the Algolaser Delta. Thanks for any help. Kas
The camera works with LightBurn, not the laser directly so at least from a compatibility perspective it should work. So unless the laser is very unique or specialized in application then the only considerations are bed size, distance from camera, and if the machine homes reliably and accurately.
Note that camera alignment only accurately works at a single focal distance from camera to material so assuming you don’t have a Z-axis bed then this might be an issue if your material height changes considerably for different jobs.
Thanks for your help that’s what I thought just wanted to check. Thanks kas
