Lightburn camera alignment on a grbl cnc machine WorkBee 1000x1000
I am unable to finish camera calibration as my z axis moves up to home position even though I have set it to the correct height of my spoil board. How can I prevent this from happening?
Hi David, I’m presuming you’re calibrating a head mounted camera then? It looks like the WorkBee uses a RepRapFirmware based control, you may need to edit the homing macro to not home the Z axis when using the laser.
Can you explain how I do this? I have a macro that sets GRBL to use Laser and a macro to set GRBL back to CNC. What command do I use?
