I have had this issue on and off a little before but since I upgraded to the latest 9.21 version the camera is freezing up a lot after sending file to cut. When I put my next piece in the laser to cut I can’t update overlay because the camera is frozen. It won’t refresh even if you select internal camera and then re select LB camera. I actually have to unplug the usb cord to camera and plug back in for the camera to work again. I have used the 8mb LB camera since it was released with this only happening once in a while. I am running windows in the shop on the laser.
