Lightburn camera is off by couple cms
So I just installed my 95 degree camera. The height is all good. Calibrated it twice and except for a couple 0.4 or so all other readings were less than 0.3 for calibration.
When I try to overlay and then cut on a small piece of wood, the laser cuts somewhere an inch away. This is even after calibrating couple times with good readings.
I have not moved anything, the door has remained open, not touched the camera, raised or lowered the bed, nothing…
I did look at another post with similar issues, the offset if not on either.
What do I do here?!
You did the camera lens calibration.
You also need to do the camera alignment.
That did it! Moral of the story, never reuse. I was using the alignment from the previous cut. I just redid the coordinates after calibration and it worked just fine. Love it!
Does it matter if I choose fisheye or standard lens when calibrating the lens? I have a 95 degree 8 MP camera.
The 8mp-95 is a standard lens. The “easy way” to tell is to look at something straight in the real world through the camera. If it’s straight in the camera preview, it’s not a fisheye lens. If it’s distorted, then it is a fisheye.
Got it, thanks!
