So I continue to have issues with lightburn recognizing the lightburn camera.
I have to disconnect the cable and reconnect then deselect lightburn camera and re-elect lightburn camera. Then maybe it will recognize it. This is every time I use it.
Any fix?
Do you have a USB extension cable on this? Only a few work reliably. When unreliable, it tends to drop the camera randomly. Mine required removing and reinserting the USB each time.
Lightburn’s “Custom Camera” option under Settings is not working with other cameras for some reason. I got it to work with “Default Camera” only.
Is there a USB extension that works?
This 16 ft one worked with my 16MP Arducam (working on the ideal setup to recommend, it has potential).
