LightBurn Camera usage for a save gcode workflow
I believe this could be made to work.
The biggest challenge will be in completing the “Calibrate Camera Alignment” process. There’s no “Save gcode” mechanism for the alignment process so I suspect you’ll have to do this manually.
Check out this post for how you could go about this:
Once completed I suspect your workflow should work fine with the camera.
