Lightburn + chinese CO2 laser
I bought a chinese laser with not user friendly software. I would like to use it in Lightburn however I have problem with settning it up with LB. I just can find the laser. When I add it manually its disconnected. Any tips?
Since all of these look the same externally, it’s nice to have a link to your specific machine.
Found this on the forum, maybe it will help…
Good luck
Assuming that it’s Running EZCad 2, then it should be compatible with LightBurn. You likely don’t have the driver for the EZCad 2 board installed if it can’t find your laser. The docs completely outline the installation process for the driver here:
