I keep getting messages that the software will not work with the new macOS 27 due to some incompatibility issues with an M-type processor. Is LightBurn compatible, or is it going to be compatible and if so when, with Mac OS 27?
If yoy are asking about ARM support, this may help.
There is another issue discussed about IOS not supporting a certain software. It will help if you provide what issue you are facing.
As I understand it this applies to the next release of MacOS sometime in 2027. Lightburn has said they will have an update before that.
This update is available with the Release Candidate version of 2.2 Index of /LightBurn/RC/LightBurn-v2.2.00-RC-3/
It installs as a separate app to your mainline LightBurn installation, so you can run each side by side without affecting your production version of LightBurn.
It appears that a Mac OS update will require that Rosetta be re-installed. Just a heads-up.
