Lightburn Computer Requirement
Would this computer be OK to run Lightburn thanks
Dell Latitude 5590 Intel i5 8350U 1.70GHz 16GB RAM 256GB SSD 15.6" Win 11
Minimum computer system requirements:envelope:
LightBurn will run on Windows 7.0 or later (32 or 64 bit), MacOS 10.11 or later, or 64 bit Linux (Ubuntu 20.04 or Fedora 36, anything else may not work as intended). Ubuntu users unable to upgrade beyond Ubuntu 18.04 should download version 1.2.01 instead of the current version.
LightBurn does not require a powerful computer for most work, though if your designs contain a lot of images, more memory is helpful. As with most things, a faster computer will make it easier to work with large images or complex vector graphics.
You’ll also want a good-sized display, with 1920×1080 being entirely adequate and 1280×1024 being too cozy.
More is better, although there are some issues around super-high resolution with display scaling.
Thank you for the answer
