Lightburn crashes frequently
I was having the same issue on Big Sur so I just recently upgraded everything to Monterey. Using the latest version of LB. Still crashing every couple of minutes. This is the error report.
Translated Report (Full Report Below)
Process: LightBurn [7473]
Path: /Applications/LightBurn 2.app/Contents/MacOS/LightBurn
Identifier: com.LightBurnSoftware.LightBurn
Version: ???
Code Type: X86-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2022-02-15 17:26:20.2736 -0500
OS Version: macOS 12.2.1 (21D62)
Report Version: 12
Anonymous UUID: 5F579708-6C7D-A15F-D5D0-80F816903F8F
Sleep/Wake UUID: CB4BFFED-4BD5-4EA3-9478-AB3C99D025ED
Time Awake Since Boot: 16000 seconds
Time Since Wake: 507 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x000052d0e312e258
Exception Codes: 0x0000000000000001, 0x000052d0e312e258
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [7473]
VM Region Info: 0x52d0e312e258 is not in any region. Bytes after previous region: 91051237036633 Bytes before following region: 14495999925672
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
__LINKEDIT 15e641000-15e6f1000 [ 704K] r–/rwx SM=COW …S/AudioCodecs
—> GAP OF 0x5ffea190f000 BYTES
MALLOC_NANO 600000000000-600008000000 [128.0M] rw-/rwx SM=PRV
Application Specific Information:
objc_msgSend() selector name: removeObserver:forKeyPath:
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libobjc.A.dylib 0x7ff80e3f905d objc_msgSend + 29
1 AVFCapture 0x7ff827e73d0f -[AVCaptureSession_Tundra removeOutput:] + 170
2 libqavfcamera.dylib 0x15625476d 0x156242000 + 75629
3 libqavfcamera.dylib 0x1562547ee 0x156242000 + 75758
4 libqavfcamera.dylib 0x15624e2b4 0x156242000 + 49844
5 libqavfcamera.dylib 0x15624e3ce 0x156242000 + 50126
6 QtMultimedia 0x10bf3c2ae 0x10bf32000 + 41646
7 QtMultimedia 0x10bf554d3 0x10bf32000 + 144595
8 QtMultimedia 0x10bf56b7c QCamera::~QCamera() + 28
9 LightBurn 0x10a70e307 CameraCap::ReleaseCamera() + 55
10 LightBurn 0x10a788a16 CameraControlWidget::ReleaseCamera() + 22
11 LightBurn 0x10a78989a CameraControlWidget::SetCamera(LBCamInfo const&) + 26
12 LightBurn 0x10a78a2d8 CameraControlWidget::on_cbCamera_currentIndexChanged(int) + 216
13 LightBurn 0x10a96cf7e CameraControlWidget::qt_metacall(QMetaObject::Call, int, void**) + 62
14 QtCore 0x10ca6f0b6 QMetaObject::activate(QObject*, int, int, void**) + 2230
15 QtWidgets 0x10d44e6f3 0x10d343000 + 1095411
16 QtWidgets 0x10d453141 0x10d343000 + 1114433
17 QtWidgets 0x10d452e1e 0x10d343000 + 1113630
18 QtCore 0x10ca6f38a QMetaObject::activate(QObject*, int, int, void**) + 2954
19 QtWidgets 0x10d450d7c QComboBoxPrivateContainer::eventFilter(QObject*, QEvent*) + 1244
20 QtCore 0x10ca3e422 QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*) + 210
21 QtWidgets 0x10d352d3d QApplicationPrivate::notify_helper(QObject*, QEvent*) + 285
22 QtWidgets 0x10d355bad QApplication::notify(QObject*, QEvent*) + 7357
23 QtCore 0x10ca3e13f QCoreApplication::notifyInternal2(QObject*, QEvent*) + 159
24 QtWidgets 0x10d353680 QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer&, bool) + 896
25 QtWidgets 0x10d3ad3c1 0x10d343000 + 435137
26 QtWidgets 0x10d3abe80 0x10d343000 + 429696
27 QtWidgets 0x10d352d52 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 306
28 QtWidgets 0x10d35412d QApplication::notify(QObject*, QEvent*) + 573
29 QtCore 0x10ca3e13f QCoreApplication::notifyInternal2(QObject*, QEvent*) + 159
30 QtGui 0x10ce48e34 QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) + 3412
31 QtGui 0x10ce488b8 QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) + 2008
32 QtGui 0x10ce30aab QWindowSystemInterface::sendWindowSystemEvents(QFlagsQEventLoop::ProcessEventsFlag) + 155
33 libqcocoa.dylib 0x10c4fda41 0x10c4d2000 + 178753
34 CoreFoundation 0x7ff80e62c8fd CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION + 17
35 CoreFoundation 0x7ff80e62c865 __CFRunLoopDoSource0 + 180
36 CoreFoundation 0x7ff80e62c5e4 __CFRunLoopDoSources0 + 242
37 CoreFoundation 0x7ff80e62b01b __CFRunLoopRun + 893
38 CoreFoundation 0x7ff80e62a5dd CFRunLoopRunSpecific + 563
39 HIToolbox 0x7ff8172674f1 RunCurrentEventLoopInMode + 292
40 HIToolbox 0x7ff817267118 ReceiveNextEventCommon + 284
41 HIToolbox 0x7ff817266fe5 _BlockUntilNextEventMatchingListInModeWithFilter + 70
42 AppKit 0x7ff811059d88 _DPSNextEvent + 886
43 AppKit 0x7ff8110583f4 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1411
44 AppKit 0x7ff81104a919 -[NSApplication run] + 586
45 libqcocoa.dylib 0x10c4fc83d 0x10c4d2000 + 174141
46 QtCore 0x10ca39c92 QEventLoop::exec(QFlagsQEventLoop::ProcessEventsFlag) + 418
47 QtCore 0x10ca3e852 QCoreApplication::exec() + 402
48 LightBurn 0x10a4ba2fd main_global(int, char**) + 3437
49 dyld 0x1197964fe start + 462
Thread 1:
0 libsystem_kernel.dylib 0x7ff80e52b3da __semwait_signal + 10
1 libsystem_c.dylib 0x7ff80e4408a9 nanosleep + 196
2 libsystem_c.dylib 0x7ff80e44b776 sleep + 41
3 LightBurn 0x10a973e75 0x10a4b2000 + 4988533
4 libsystem_pthread.dylib 0x7ff80e5654f4 _pthread_start + 125
5 libsystem_pthread.dylib 0x7ff80e56100f thread_start + 15
Thread 2:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x7ff80e530e4a __select + 10
1 CoreFoundation 0x7ff80e653ecd __CFSocketManager + 630
2 libsystem_pthread.dylib 0x7ff80e5654f4 _pthread_start + 125
3 libsystem_pthread.dylib 0x7ff80e56100f thread_start + 15
Thread 3:: AMCP Logging Spool
0 libsystem_kernel.dylib 0x7ff80e528af6 semaphore_wait_trap + 10
1 caulk 0x7ff816fef1c0 caulk::mach::semaphore::wait_or_error() + 16
2 caulk 0x7ff816fd608a caulk::concurrent::details::worker_thread::run() + 36
3 caulk 0x7ff816fd5d4e void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::)(), std::__1::tuplecaulk::concurrent::details::worker_thread* > >(void) + 41
Thread 4:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x7ff80e528aba mach_msg_trap + 10
1 libsystem_kernel.dylib 0x7ff80e528e2b mach_msg + 59
2 CoreFoundation 0x7ff80e62caf2 __CFRunLoopServiceMachPort + 319
3 CoreFoundation 0x7ff80e62b1cb __CFRunLoopRun + 1325
4 CoreFoundation 0x7ff80e62a5dd CFRunLoopRunSpecific + 563
5 AppKit 0x7ff8111c7fd8 _NSEventThread + 132
6 libsystem_pthread.dylib 0x7ff80e5654f4 _pthread_start + 125
7 libsystem_pthread.dylib 0x7ff80e56100f thread_start + 15
Thread 5:
0 libsystem_pthread.dylib 0x7ff80e560fec start_wqthread + 0
Thread 6:
Thread 7:: Dispatch queue: com.apple.root.user-interactive-qos
0 libsystem_kernel.dylib 0x7ff80e528b0e semaphore_timedwait_trap + 10
1 libdispatch.dylib 0x7ff80e3af1f2 _dispatch_sema4_timedwait + 72
2 libdispatch.dylib 0x7ff80e3af61f _dispatch_semaphore_wait_slow + 58
3 AppKit 0x7ff811930d9b __22-[NSCGSLocalFence set]_block_invoke_2 + 147
4 QuartzCore 0x7ff8156aa384 CA::Transaction::run_commit_handlers(CATransactionPhase) + 98
5 QuartzCore 0x7ff815817816 CA::Context::commit_transaction(CA::Transaction*, double, double*) + 952
6 QuartzCore 0x7ff8156a924a CA::Transaction::commit() + 704
7 AppKit 0x7ff8110a8e47 NSPerformVisuallyAtomicChange + 154
8 AppKit 0x7ff81147d969 __30-[NSAnimation _runInNewThread]_block_invoke + 80
9 libdispatch.dylib 0x7ff80e3adad8 _dispatch_call_block_and_release + 12
10 libdispatch.dylib 0x7ff80e3aecc9 _dispatch_client_callout + 8
11 libdispatch.dylib 0x7ff80e3be50b _dispatch_root_queue_drain + 680
12 libdispatch.dylib 0x7ff80e3beb5a _dispatch_worker_thread2 + 160
13 libsystem_pthread.dylib 0x7ff80e56202e _pthread_wqthread + 256
14 libsystem_pthread.dylib 0x7ff80e560ffb start_wqthread + 15
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x00000000ed8208f7 rbx: 0x000060000171e240 rcx: 0x00007ff84fa8d858 rdx: 0x000060000171f160
rdi: 0x000060000171e240 rsi: 0x00007ff828d43d55 rbp: 0x00007ff7b5a4abd0 rsp: 0x00007ff7b5a4aab8
r8: 0x0000000000002240 r9: 0x0000000000000020 r10: 0x000052d0e312e240 r11: 0x00007ff828d43d55
r12: 0x0000000000000000 r13: 0x000000010cd7be28 r14: 0x000060000171f160 r15: 0x00007ff80e3f9040
rip: 0x00007ff80e3f905d rfl: 0x0000000000010202 cr2: 0x000052d0e312e258
Logical CPU: 2
Error Code: 0x00000004 (no mapping for user data read)
Trap Number: 14
Thread 0 instruction stream:
49 83 c3 10 49 3b 33 75-f1 49 8b 43 08 48 83 f8 I…I;3u.I.C.H…
00 74 03 4c 31 d0 c3 eb-00 31 c0 c3 66 66 66 66 .t.L1…1…ffff
66 66 2e 0f 1f 84 00 00-00 00 00 66 66 66 66 66 ff…fffff
66 2e 0f 1f 84 00 00 00-00 00 66 0f 1f 44 00 00 f…f…D…
48 85 ff 2e 74 72 40 f6-c7 01 2e 75 76 49 ba f8 H…tr@…uvI…
ff ff ff ff 7f 00 00 4c-23 17 49 89 f3[45]23 5a …L#.I…E#Z <==
18 49 c1 e3 04 4d 03 5a-10 49 3b 33 75 0a 4d 8b .I…M.Z.I;3u.M.
5b 08 4d 31 d3 41 ff e3-49 83 3b 01 76 13 49 83 [.M1.A…I.;.v.I.
c3 10 49 3b 33 75 f1 4d-8b 5b 08 4d 31 d3 41 ff …I;3u.M.[.M1.A.
e3 72 70 4d 8b 5b 08 eb-0a 49 83 3b 01 76 13 49 .rpM.[…I.;.v.I
83 c3 10 49 3b 33 75 f1-4d 8b 5b 08 4d 31 d3 41 …I;3u.M.[.M1.A
ff e3 eb 4f 0f 1f 40 00-31 c0 31 d2 0f 57 c0 0f …O…@.1.1…W…
Binary Images:
0x7ff80e3f3000 - 0x7ff80e42cfff libobjc.A.dylib () <33f2dc54-09f1-377f-9273-5da971aaa102> /usr/lib/libobjc.A.dylib
0x7ff827e52000 - 0x7ff827fa1fff com.apple.AVFCapture (1.0) <7d7b26c7-f751-3b50-8229-f5a8bfe0a227> /System/Library/PrivateFrameworks/AVFCapture.framework/Versions/A/AVFCapture
0x156242000 - 0x15626ffff libqavfcamera.dylib (
) /Applications/LightBurn 2.app/Contents/PlugIns/mediaservice/libqavfcamera.dylib
0x10bf32000 - 0x10bfa7fff org.qt-project.QtMultimedia (5.11) /Applications/LightBurn 2.app/Contents/Frameworks/QtMultimedia.framework/Versions/5/QtMultimedia
0x10a4b2000 - 0x10b8fdfff com.LightBurnSoftware.LightBurn () <3c570321-3fa0-357c-a596-85ab62d710ab> /Applications/LightBurn 2.app/Contents/MacOS/LightBurn
0x10c861000 - 0x10cd4cfff org.qt-project.QtCore (5.11) <02cecf89-9d8b-3cad-a3d9-0618e34152bf> /Applications/LightBurn 2.app/Contents/Frameworks/QtCore.framework/Versions/5/QtCore
0x10d343000 - 0x10d776fff org.qt-project.QtWidgets (5.11) /Applications/LightBurn 2.app/Contents/Frameworks/QtWidgets.framework/Versions/5/QtWidgets
0x10ce19000 - 0x10d232fff org.qt-project.QtGui (5.11) <09bf520b-88b0-3401-8c6a-08d9510c6351> /Applications/LightBurn 2.app/Contents/Frameworks/QtGui.framework/Versions/5/QtGui
0x10c4d2000 - 0x10c625fff libqcocoa.dylib (
) /Applications/LightBurn 2.app/Contents/PlugIns/platforms/libqcocoa.dylib
0x7ff80e5ac000 - 0x7ff80eaaefff com.apple.CoreFoundation (6.9) <9b112884-be6c-3c7f-9a2a-a47c491105db> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7ff817235000 - 0x7ff81752cfff com.apple.HIToolbox (2.1.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7ff81101b000 - 0x7ff811eacfff com.apple.AppKit (6.9) <9d3ab204-4858-3120-b002-5c38b02edec4> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x119791000 - 0x1197fcfff dyld () <7de33963-bbc5-3996-ba6e-f1d562c17c95> /usr/lib/dyld
0x7ff80e528000 - 0x7ff80e55efff libsystem_kernel.dylib (
) /usr/lib/system/libsystem_kernel.dylib
0x7ff80e430000 - 0x7ff80e4b8fff libsystem_c.dylib () <4b160c81-ec52-3243-aaba-49f719bbf617> /usr/lib/system/libsystem_c.dylib
0x7ff80e55f000 - 0x7ff80e56afff libsystem_pthread.dylib (
) /usr/lib/system/libsystem_pthread.dylib
0x7ff816fd4000 - 0x7ff816ff6fff com.apple.audio.caulk (1.0) <0a60f9ec-f83c-388e-bcb1-43b785c997d1> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
0x7ff80e3ac000 - 0x7ff80e3f2fff libdispatch.dylib () <67d92c93-aa68-34c2-964b-23e8a8d32098> /usr/lib/system/libdispatch.dylib
0x7ff8156a7000 - 0x7ff81598ffff com.apple.QuartzCore (1.11) <9e727a38-d1d3-3d6a-940c-0ebfa61e28e6> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x0 - 0xffffffffffffffff ??? (
) <00000000-0000-0000-0000-000000000000> ???
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)
Writable regions: Total=879.4M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=879.4M(100%)
                            VIRTUAL   REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 512K 4
Activity Tracing 256K 1
CG backing stores 1920K 4
CG image 496K 30
ColorSync 232K 27
CoreAnimation 364K 8
CoreGraphics 12K 2
CoreImage 28K 6
CoreMedia memory pool 848K 2
CoreServices 152K 1
CoreUI image data 3340K 26
Foundation 16K 1
Kernel Alloc Once 8K 1
MALLOC 478.5M 430
MALLOC guard page 32K 8
MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)
STACK GUARD 56.0M 8
Stack 11.6M 8
VM_ALLOCATE 332K 18
__DATA 27.5M 459
__DATA_CONST 22.5M 277
__DATA_DIRTY 1301K 168
__FONT_DATA 4K 1
__LINKEDIT 649.8M 45
__OBJC_RO 81.8M 1
__OBJC_RW 3136K 2
__TEXT 401.9M 472
__UNICODE 588K 1
dyld private memory 1088K 3
mapped file 1.2G 1006
shared memory 772K 17
TOTAL 3.3G 3038
TOTAL, minus reserved VM space 2.9G 3038
Full Report
{“app_name”:“LightBurn”,“timestamp”:“2022-02-15 17:26:20.00 -0500”,“app_version”:"",“slice_uuid”:“3c570321-3fa0-357c-a596-85ab62d710ab”,“build_version”:"",“platform”:1,“bundleID”:“com.LightBurnSoftware.LightBurn”,“share_with_app_devs”:0,“is_first_party”:0,“bug_type”:“309”,“os_version”:“macOS 12.2.1 (21D62)”,“incident_id”:“A596543A-D840-41F1-A0D0-167B35218C61”,“name”:“LightBurn”}
“uptime” : 16000,
“procLaunch” : “2022-02-15 16:40:46.3316 -0500”,
“procRole” : “Foreground”,
“version” : 2,
“userID” : 501,
“deployVersion” : 210,
“modelCode” : “MacBookPro12,1”,
“procStartAbsTime” : 14987316209397,
“coalitionID” : 2246,
“osVersion” : {
“train” : “macOS 12.2.1”,
“build” : “21D62”,
“releaseType” : “User”
“captureTime” : “2022-02-15 17:26:20.2736 -0500”,
“incident” : “A596543A-D840-41F1-A0D0-167B35218C61”,
“bug_type” : “309”,
“pid” : 7473,
“procExitAbsTime” : 16196830020807,
“cpuType” : “X86-64”,
“procName” : “LightBurn”,
“procPath” : “/Applications/LightBurn 2.app/Contents/MacOS/LightBurn”,
“bundleInfo” : {“CFBundleIdentifier”:“com.LightBurnSoftware.LightBurn”},
“storeInfo” : {“deviceIdentifierForVendor”:“CF9EBFF3-E2E3-5F2E-98AC-59A449F68CA9”,“thirdParty”:true},
“parentProc” : “launchd”,
“parentPid” : 1,
“coalitionName” : “com.LightBurnSoftware.LightBurn”,
“crashReporterKey” : “5F579708-6C7D-A15F-D5D0-80F816903F8F”,
“wakeTime” : 507,
“sleepWakeUUID” : “CB4BFFED-4BD5-4EA3-9478-AB3C99D025ED”,
“sip” : “enabled”,
“vmRegionInfo” : “0x52d0e312e258 is not in any region. Bytes after previous region: 91051237036633 Bytes before following region: 14495999925672\n REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL\n __LINKEDIT 15e641000-15e6f1000 [ 704K] r–/rwx SM=COW …S/AudioCodecs\n—> GAP OF 0x5ffea190f000 BYTES\n MALLOC_NANO 600000000000-600008000000 [128.0M] rw-/rwx SM=PRV “,
“isCorpse” : 1,
“exception” : {“codes”:“0x0000000000000001, 0x000052d0e312e258”,“rawCodes”:[1,91057116340824],“type”:“EXC_BAD_ACCESS”,“signal”:“SIGSEGV”,“subtype”:“KERN_INVALID_ADDRESS at 0x000052d0e312e258”},
“termination” : {“flags”:0,“code”:11,“namespace”:“SIGNAL”,“indicator”:“Segmentation fault: 11”,“byProc”:“exc handler”,“byPid”:7473},
“vmregioninfo” : “0x52d0e312e258 is not in any region. Bytes after previous region: 91051237036633 Bytes before following region: 14495999925672\n REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL\n __LINKEDIT 15e641000-15e6f1000 [ 704K] r–/rwx SM=COW …S/AudioCodecs\n—> GAP OF 0x5ffea190f000 BYTES\n MALLOC_NANO 600000000000-600008000000 [128.0M] rw-/rwx SM=PRV “,
“asi” : {“objc”:[“objc_msgSend() selector name: removeObserver:forKeyPath:”]},
“extMods” : {“caller”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“system”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“targeted”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“warnings”:0},
“faultingThread” : 0,
“threads” : [{“triggered”:true,“id”:113358,“instructionState”:{“instructionStream”:{“bytes”:[73,131,195,16,73,59,51,117,241,73,139,67,8,72,131,248,0,116,3,76,49,208,195,235,0,49,192,195,102,102,102,102,102,102,46,15,31,132,0,0,0,0,0,102,102,102,102,102,102,46,15,31,132,0,0,0,0,0,102,15,31,68,0,0,72,133,255,46,116,114,64,246,199,1,46,117,118,73,186,248,255,255,255,255,127,0,0,76,35,23,73,137,243,69,35,90,24,73,193,227,4,77,3,90,16,73,59,51,117,10,77,139,91,8,77,49,211,65,255,227,73,131,59,1,118,19,73,131,195,16,73,59,51,117,241,77,139,91,8,77,49,211,65,255,227,114,112,77,139,91,8,235,10,73,131,59,1,118,19,73,131,195,16,73,59,51,117,241,77,139,91,8,77,49,211,65,255,227,235,79,15,31,64,0,49,192,49,210,15,87,192,15],“offset”:93}},“threadState”:{“r13”:{“value”:4510432808},“rax”:{“value”:3984722167},“rflags”:{“value”:66050},“cpu”:{“value”:2},“r14”:{“value”:105553140511072},“rsi”:{“value”:140703813614933,“objc-selector”:“removeObserver:forKeyPath:”},“r8”:{“value”:8768},“cr2”:{“value”:91057116340824},“rdx”:{“value”:105553140511072},“r10”:{“value”:91057116340800},“r9”:{“value”:32},“r15”:{“value”:140703367663680,“symbolLocation”:0,“symbol”:“objc_msgSend”},“rbx”:{“value”:105553140507200},“trap”:{“value”:14,“description”:”(no mapping for user data read)”},“err”:{“value”:4},“r11”:{“value”:140703813614933,“objc-selector”:“removeObserver:forKeyPath:”},“rip”:{“value”:140703367663709,“matchesCrashFrame”:1},“rbp”:{“value”:140701881117648},“rsp”:{“value”:140701881117368},“r12”:{“value”:0},“rcx”:{“value”:140704465082456},“flavor”:“x86_THREAD_STATE”,“rdi”:{“value”:105553140507200}},“queue”:“com.apple.main-thread”,“frames”:[{“imageOffset”:24669,“symbol”:“objc_msgSend”,“symbolLocation”:29,“imageIndex”:0},{“imageOffset”:138511,“symbol”:”-[AVCaptureSession_Tundra removeOutput:]”,“symbolLocation”:170,“imageIndex”:1},{“imageOffset”:75629,“imageIndex”:2},{“imageOffset”:75758,“imageIndex”:2},{“imageOffset”:49844,“imageIndex”:2},{“imageOffset”:50126,“imageIndex”:2},{“imageOffset”:41646,“imageIndex”:3},{“imageOffset”:144595,“imageIndex”:3},{“imageOffset”:150396,“symbol”:“QCamera::~QCamera()”,“symbolLocation”:28,“imageIndex”:3},{“imageOffset”:2474759,“symbol”:“CameraCap::ReleaseCamera()”,“symbolLocation”:55,“imageIndex”:4},{“imageOffset”:2976278,“symbol”:“CameraControlWidget::ReleaseCamera()”,“symbolLocation”:22,“imageIndex”:4},{“imageOffset”:2979994,“symbol”:“CameraControlWidget::SetCamera(LBCamInfo const&)”,“symbolLocation”:26,“imageIndex”:4},{“imageOffset”:2982616,“symbol”:“CameraControlWidget::on_cbCamera_currentIndexChanged(int)”,“symbolLocation”:216,“imageIndex”:4},{“imageOffset”:4960126,“symbol”:“CameraControlWidget::qt_metacall(QMetaObject::Call, int, void**)”,“symbolLocation”:62,“imageIndex”:4},{“imageOffset”:2154678,“symbol”:“QMetaObject::activate(QObject*, int, int, void**)”,“symbolLocation”:2230,“imageIndex”:5},{“imageOffset”:1095411,“imageIndex”:6},{“imageOffset”:1114433,“imageIndex”:6},{“imageOffset”:1113630,“imageIndex”:6},{“imageOffset”:2155402,“symbol”:“QMetaObject::activate(QObject*, int, int, void**)”,“symbolLocation”:2954,“imageIndex”:5},{“imageOffset”:1105276,“symbol”:“QComboBoxPrivateContainer::eventFilter(QObject*, QEvent*)”,“symbolLocation”:1244,“imageIndex”:6},{“imageOffset”:1954850,“symbol”:“QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*)”,“symbolLocation”:210,“imageIndex”:5},{“imageOffset”:64829,“symbol”:“QApplicationPrivate::notify_helper(QObject*, QEvent*)”,“symbolLocation”:285,“imageIndex”:6},{“imageOffset”:76717,“symbol”:“QApplication::notify(QObject*, QEvent*)”,“symbolLocation”:7357,“imageIndex”:6},{“imageOffset”:1954111,“symbol”:“QCoreApplication::notifyInternal2(QObject*, QEvent*)”,“symbolLocation”:159,“imageIndex”:5},{“imageOffset”:67200,“symbol”:“QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer&, bool)”,“symbolLocation”:896,“imageIndex”:6},{“imageOffset”:435137,“imageIndex”:6},{“imageOffset”:429696,“imageIndex”:6},{“imageOffset”:64850,“symbol”:“QApplicationPrivate::notify_helper(QObject*, QEvent*)”,“symbolLocation”:306,“imageIndex”:6},{“imageOffset”:69933,“symbol”:“QApplication::notify(QObject*, QEvent*)”,“symbolLocation”:573,“imageIndex”:6},{“imageOffset”:1954111,“symbol”:“QCoreApplication::notifyInternal2(QObject*, QEvent*)”,“symbolLocation”:159,“imageIndex”:5},{“imageOffset”:196148,“symbol”:“QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*)”,“symbolLocation”:3412,“imageIndex”:7},{“imageOffset”:194744,“symbol”:“QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*)”,“symbolLocation”:2008,“imageIndex”:7},{“imageOffset”:96939,“symbol”:“QWindowSystemInterface::sendWindowSystemEvents(QFlagsQEventLoop::ProcessEventsFlag)”,“symbolLocation”:155,“imageIndex”:7},{“imageOffset”:178753,“imageIndex”:8},{“imageOffset”:526589,“symbol”:“CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION”,“symbolLocation”:17,“imageIndex”:9},{“imageOffset”:526437,“symbol”:"__CFRunLoopDoSource0",“symbolLocation”:180,“imageIndex”:9},{“imageOffset”:525796,“symbol”:"__CFRunLoopDoSources0",“symbolLocation”:242,“imageIndex”:9},{“imageOffset”:520219,“symbol”:"__CFRunLoopRun",“symbolLocation”:893,“imageIndex”:9},{“imageOffset”:517597,“symbol”:“CFRunLoopRunSpecific”,“symbolLocation”:563,“imageIndex”:9},{“imageOffset”:206065,“symbol”:“RunCurrentEventLoopInMode”,“symbolLocation”:292,“imageIndex”:10},{“imageOffset”:205080,“symbol”:“ReceiveNextEventCommon”,“symbolLocation”:284,“imageIndex”:10},{“imageOffset”:204773,“symbol”:"_BlockUntilNextEventMatchingListInModeWithFilter",“symbolLocation”:70,“imageIndex”:10},{“imageOffset”:257416,“symbol”:"_DPSNextEvent",“symbolLocation”:886,“imageIndex”:11},{“imageOffset”:250868,“symbol”:"-[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]",“symbolLocation”:1411,“imageIndex”:11},{“imageOffset”:194841,“symbol”:"-[NSApplication run]",“symbolLocation”:586,“imageIndex”:11},{“imageOffset”:174141,“imageIndex”:8},{“imageOffset”:1936530,“symbol”:“QEventLoop::exec(QFlagsQEventLoop::ProcessEventsFlag)”,“symbolLocation”:418,“imageIndex”:5},{“imageOffset”:1955922,“symbol”:“QCoreApplication::exec()”,“symbolLocation”:402,“imageIndex”:5},{“imageOffset”:33533,“symbol”:“main_global(int, char**)”,“symbolLocation”:3437,“imageIndex”:4},{“imageOffset”:21758,“symbol”:“start”,“symbolLocation”:462,“imageIndex”:12}]},{“id”:113441,“frames”:[{“imageOffset”:13274,“symbol”:"__semwait_signal",“symbolLocation”:10,“imageIndex”:13},{“imageOffset”:67753,“symbol”:“nanosleep”,“symbolLocation”:196,“imageIndex”:14},{“imageOffset”:112502,“symbol”:“sleep”,“symbolLocation”:41,“imageIndex”:14},{“imageOffset”:4988533,“imageIndex”:4},{“imageOffset”:25844,“symbol”:"_pthread_start",“symbolLocation”:125,“imageIndex”:15},{“imageOffset”:8207,“symbol”:“thread_start”,“symbolLocation”:15,“imageIndex”:15}]},{“id”:113512,“name”:“com.apple.CFSocket.private”,“frames”:[{“imageOffset”:36426,“symbol”:"__select",“symbolLocation”:10,“imageIndex”:13},{“imageOffset”:687821,“symbol”:"__CFSocketManager",“symbolLocation”:630,“imageIndex”:9},{“imageOffset”:25844,“symbol”:"_pthread_start",“symbolLocation”:125,“imageIndex”:15},{“imageOffset”:8207,“symbol”:“thread_start”,“symbolLocation”:15,“imageIndex”:15}]},{“id”:113520,“name”:“AMCP Logging Spool”,“frames”:[{“imageOffset”:2806,“symbol”:“semaphore_wait_trap”,“symbolLocation”:10,“imageIndex”:13},{“imageOffset”:111040,“symbol”:“caulk::mach::semaphore::wait_or_error()”,“symbolLocation”:16,“imageIndex”:16},{“imageOffset”:8330,“symbol”:“caulk::concurrent::details::worker_thread::run()”,“symbolLocation”:36,“imageIndex”:16},{“imageOffset”:7502,“symbol”:“void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::)(), std::__1::tuplecaulk::concurrent::details::worker_thread* > >(void)”,“symbolLocation”:41,“imageIndex”:16},{“imageOffset”:25844,“symbol”:"_pthread_start",“symbolLocation”:125,“imageIndex”:15},{“imageOffset”:8207,“symbol”:“thread_start”,“symbolLocation”:15,“imageIndex”:15}]},{“id”:113599,“name”:“com.apple.NSEventThread”,“frames”:[{“imageOffset”:2746,“symbol”:“mach_msg_trap”,“symbolLocation”:10,“imageIndex”:13},{“imageOffset”:3627,“symbol”:“mach_msg”,“symbolLocation”:59,“imageIndex”:13},{“imageOffset”:527090,“symbol”:"__CFRunLoopServiceMachPort",“symbolLocation”:319,“imageIndex”:9},{“imageOffset”:520651,“symbol”:"__CFRunLoopRun",“symbolLocation”:1325,“imageIndex”:9},{“imageOffset”:517597,“symbol”:“CFRunLoopRunSpecific”,“symbolLocation”:563,“imageIndex”:9},{“imageOffset”:1757144,“symbol”:"_NSEventThread",“symbolLocation”:132,“imageIndex”:11},{“imageOffset”:25844,“symbol”:"_pthread_start",“symbolLocation”:125,“imageIndex”:15},{“imageOffset”:8207,“symbol”:“thread_start”,“symbolLocation”:15,“imageIndex”:15}]},{“id”:121470,“frames”:[{“imageOffset”:8172,“symbol”:“start_wqthread”,“symbolLocation”:0,“imageIndex”:15}]},{“id”:123537,“frames”:[{“imageOffset”:8172,“symbol”:“start_wqthread”,“symbolLocation”:0,“imageIndex”:15}]},{“id”:123538,“queue”:“com.apple.root.user-interactive-qos”,“frames”:[{“imageOffset”:2830,“symbol”:“semaphore_timedwait_trap”,“symbolLocation”:10,“imageIndex”:13},{“imageOffset”:12786,“symbol”:"_dispatch_sema4_timedwait",“symbolLocation”:72,“imageIndex”:17},{“imageOffset”:13855,“symbol”:"_dispatch_semaphore_wait_slow",“symbolLocation”:58,“imageIndex”:17},{“imageOffset”:9526683,“symbol”:"__22-[NSCGSLocalFence set]_block_invoke_2",“symbolLocation”:147,“imageIndex”:11},{“imageOffset”:13188,“symbol”:“CA::Transaction::run_commit_handlers(CATransactionPhase)”,“symbolLocation”:98,“imageIndex”:18},{“imageOffset”:1509398,“symbol”:“CA::Context::commit_transaction(CA::Transaction*, double, double*)”,“symbolLocation”:952,“imageIndex”:18},{“imageOffset”:8778,“symbol”:“CA::Transaction::commit()”,“symbolLocation”:704,“imageIndex”:18},{“imageOffset”:581191,“symbol”:“NSPerformVisuallyAtomicChange”,“symbolLocation”:154,“imageIndex”:11},{“imageOffset”:4598121,“symbol”:"__30-[NSAnimation _runInNewThread]_block_invoke",“symbolLocation”:80,“imageIndex”:11},{“imageOffset”:6872,“symbol”:"_dispatch_call_block_and_release",“symbolLocation”:12,“imageIndex”:17},{“imageOffset”:11465,“symbol”:"_dispatch_client_callout",“symbolLocation”:8,“imageIndex”:17},{“imageOffset”:75019,“symbol”:"_dispatch_root_queue_drain",“symbolLocation”:680,“imageIndex”:17},{“imageOffset”:76634,“symbol”:"_dispatch_worker_thread2",“symbolLocation”:160,“imageIndex”:17},{“imageOffset”:12334,“symbol”:"_pthread_wqthread",“symbolLocation”:256,“imageIndex”:15},{“imageOffset”:8187,“symbol”:“start_wqthread”,“symbolLocation”:15,“imageIndex”:15}]}],
“usedImages” : [
“source” : “P”,
“arch” : “x86_64h”,
“base” : 140703367639040,
“size” : 237568,
“uuid” : “33f2dc54-09f1-377f-9273-5da971aaa102”,
“path” : “/usr/lib/libobjc.A.dylib”,
“name” : “libobjc.A.dylib”
“source” : “P”,
“arch” : “x86_64”,
“base” : 140703797944320,
“CFBundleShortVersionString” : “1.0”,
“CFBundleIdentifier” : “com.apple.AVFCapture”,
“size” : 1376256,
“uuid” : “7d7b26c7-f751-3b50-8229-f5a8bfe0a227”,
“path” : “/System/Library/PrivateFrameworks/AVFCapture.framework/Versions/A/AVFCapture”,
“name” : “AVFCapture”,
“CFBundleVersion” : “186.4”
“source” : “P”,
“arch” : “x86_64”,
“base” : 5740175360,
“size” : 188416,
“uuid” : “add4e48c-c3ca-366f-8e68-95fb3f761f42”,
“path” : “/Applications/LightBurn 2.app/Contents/PlugIns/mediaservice/libqavfcamera.dylib”,
“name” : “libqavfcamera.dylib”
“source” : “P”,
“arch” : “x86_64”,
“base” : 4495450112,
“CFBundleShortVersionString” : “5.11”,
“CFBundleIdentifier” : “org.qt-project.QtMultimedia”,
“size” : 483328,
“uuid” : “daef22f9-8b2a-3d02-b389-47d1a25bd86e”,
“path” : “/Applications/LightBurn 2.app/Contents/Frameworks/QtMultimedia.framework/Versions/5/QtMultimedia”,
“name” : “QtMultimedia”,
“CFBundleVersion” : “5.11.3”
“source” : “P”,
“arch” : “x86_64”,
“base” : 4467662848,
“CFBundleIdentifier” : “com.LightBurnSoftware.LightBurn”,
“size” : 21282816,
“uuid” : “3c570321-3fa0-357c-a596-85ab62d710ab”,
“path” : “/Applications/LightBurn 2.app/Contents/MacOS/LightBurn”,
“name” : “LightBurn”
“source” : “P”,
“arch” : “x86_64”,
“base” : 4505079808,
“CFBundleIdentifier” : “org.qt-project.QtCore”,
“size” : 5160960,
“uuid” : “02cecf89-9d8b-3cad-a3d9-0618e34152bf”,
“path” : “/Applications/LightBurn 2.app/Contents/Frameworks/QtCore.framework/Versions/5/QtCore”,
“name” : “QtCore”,
“source” : “P”,
“arch” : “x86_64”,
“base” : 4516491264,
“CFBundleIdentifier” : “org.qt-project.QtWidgets”,
“size” : 4407296,
“uuid” : “a7aeae0d-ef52-3183-9bca-8a9556b0634a”,
“path” : “/Applications/LightBurn 2.app/Contents/Frameworks/QtWidgets.framework/Versions/5/QtWidgets”,
“name” : “QtWidgets”,
“source” : “P”,
“arch” : “x86_64”,
“base” : 4511076352,
“CFBundleIdentifier” : “org.qt-project.QtGui”,
“size” : 4300800,
“uuid” : “09bf520b-88b0-3401-8c6a-08d9510c6351”,
“path” : “/Applications/LightBurn 2.app/Contents/Frameworks/QtGui.framework/Versions/5/QtGui”,
“name” : “QtGui”,
“source” : “P”,
“arch” : “x86_64”,
“base” : 4501348352,
“size” : 1392640,
“uuid” : “a105c389-87cd-3a14-987b-d4aebd825ccf”,
“path” : “/Applications/LightBurn 2.app/Contents/PlugIns/platforms/libqcocoa.dylib”,
“name” : “libqcocoa.dylib”
“source” : “P”,
“arch” : “x86_64h”,
“base” : 140703369445376,
“CFBundleShortVersionString” : “6.9”,
“CFBundleIdentifier” : “com.apple.CoreFoundation”,
“size” : 5255168,
“uuid” : “9b112884-be6c-3c7f-9a2a-a47c491105db”,
“path” : “/System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation”,
“name” : “CoreFoundation”,
“CFBundleVersion” : “1856.107”
“source” : “P”,
“arch” : “x86_64”,
“base” : 140703516807168,
“CFBundleShortVersionString” : “2.1.1”,
“CFBundleIdentifier” : “com.apple.HIToolbox”,
“size” : 3112960,
“uuid” : “c538aa78-7afd-3f8a-8fdb-1fc2acde6b3f”,
“path” : “/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox”,
“name” : “HIToolbox”
“source” : “P”,
“arch” : “x86_64”,
“base” : 140703413940224,
“CFBundleIdentifier” : “com.apple.AppKit”,
“size” : 15278080,
“uuid” : “9d3ab204-4858-3120-b002-5c38b02edec4”,
“path” : “/System/Library/Frameworks/AppKit.framework/Versions/C/AppKit”,
“name” : “AppKit”,
“CFBundleVersion” : “2113.30.116”
“source” : “P”,
“arch” : “x86_64”,
“base” : 4722331648,
“size” : 442368,
“uuid” : “7de33963-bbc5-3996-ba6e-f1d562c17c95”,
“path” : “/usr/lib/dyld”,
“name” : “dyld”
“source” : “P”,
“arch” : “x86_64”,
“base” : 140703368904704,
“size” : 225280,
“uuid” : “c1d58a50-5a4d-3bcb-a1fc-ec0902ce34d3”,
“path” : “/usr/lib/system/libsystem_kernel.dylib”,
“name” : “libsystem_kernel.dylib”
“source” : “P”,
“arch” : “x86_64”,
“base” : 140703367888896,
“size” : 561152,
“uuid” : “4b160c81-ec52-3243-aaba-49f719bbf617”,
“path” : “/usr/lib/system/libsystem_c.dylib”,
“name” : “libsystem_c.dylib”
“source” : “P”,
“arch” : “x86_64”,
“base” : 140703369129984,
“size” : 49152,
“uuid” : “ee564342-d8f2-396d-b642-40092cf34d82”,
“path” : “/usr/lib/system/libsystem_pthread.dylib”,
“name” : “libsystem_pthread.dylib”
“source” : “P”,
“arch” : “x86_64”,
“base” : 140703514312704,
“CFBundleIdentifier” : “com.apple.audio.caulk”,
“size” : 143360,
“uuid” : “0a60f9ec-f83c-388e-bcb1-43b785c997d1”,
“path” : “/System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk”,
“name” : “caulk”
“source” : “P”,
“arch” : “x86_64”,
“base” : 140703367348224,
“size” : 290816,
“uuid” : “67d92c93-aa68-34c2-964b-23e8a8d32098”,
“path” : “/usr/lib/system/libdispatch.dylib”,
“name” : “libdispatch.dylib”
“source” : “P”,
“arch” : “x86_64”,
“base” : 140703487913984,
“CFBundleShortVersionString” : “1.11”,
“CFBundleIdentifier” : “com.apple.QuartzCore”,
“size” : 3051520,
“uuid” : “9e727a38-d1d3-3d6a-940c-0ebfa61e28e6”,
“path” : “/System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore”,
“name” : “QuartzCore”,
“CFBundleVersion” : “962.63”
“size” : 0,
“source” : “A”,
“base” : 0,
“uuid” : “00000000-0000-0000-0000-000000000000”
“sharedCache” : {
“base” : 140703365898240,
“size” : 15216836608,
“uuid” : “0939015d-8308-3e69-b095-bd928f835202”
“vmSummary” : “ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)\nWritable regions: Total=879.4M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=879.4M(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 512K 4 \nActivity Tracing 256K 1 \nCG backing stores 1920K 4 \nCG image 496K 30 \nColorSync 232K 27 \nCoreAnimation 364K 8 \nCoreGraphics 12K 2 \nCoreImage 28K 6 \nCoreMedia memory pool 848K 2 \nCoreServices 152K 1 \nCoreUI image data 3340K 26 \nFoundation 16K 1 \nKernel Alloc Once 8K 1 \nMALLOC 478.5M 430 \nMALLOC guard page 32K 8 \nMALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)\nSTACK GUARD 56.0M 8 \nStack 11.6M 8 \nVM_ALLOCATE 332K 18 \n__DATA 27.5M 459 \n__DATA_CONST 22.5M 277 \n__DATA_DIRTY 1301K 168 \n__FONT_DATA 4K 1 \n__LINKEDIT 649.8M 45 \n__OBJC_RO 81.8M 1 \n__OBJC_RW 3136K 2 \n__TEXT 401.9M 472 \n__UNICODE 588K 1 \ndyld private memory 1088K 3 \nmapped file 1.2G 1006 \nshared memory 772K 17 \n=========== ======= ======= \nTOTAL 3.3G 3038 \nTOTAL, minus reserved VM space 2.9G 3038 \n”,
“legacyInfo” : {
“threadTriggered” : {
“queue” : “com.apple.main-thread”
“trialInfo” : {
“rollouts” : [
“rolloutId” : “601d9415f79519000ccd4b69”,
“factorPackIds” : {
“SIRI_TEXT_TO_SPEECH” : “620161cb295c182621eced20”
“deploymentId” : 240000392
“rolloutId” : “5fc94383418129005b4e9ae0”,
“factorPackIds” : {
  "deploymentId" : 240000231
  "rolloutId" : "607844aa04477260f58a8077",
  "factorPackIds" : {
    "SIRI_MORPHUN_ASSETS" : "6103050cbfe6dc472e1c982a"
  "deploymentId" : 240000066
  "rolloutId" : "5ffde50ce2aacd000d47a95f",
  "factorPackIds" : {
  "deploymentId" : 240000106
  "rolloutId" : "602ad4dac86151000cf27e46",
  "factorPackIds" : {
    "SIRI_DICTATION_ASSETS" : "6193d03f2171a2330e561dfc"
  "deploymentId" : 240000305
  "rolloutId" : "60da5e84ab0ca017dace9abf",
  "factorPackIds" : {
  "deploymentId" : 240000008
“experiments” : [
Model: MacBookPro12,1, BootROM 428.60.3.0.0, 2 processors, Dual-Core Intel Core i5, 2.7 GHz, 8 GB, SMC 2.28f7
Graphics: Intel Iris Graphics 6100, Intel Iris Graphics 6100, Built-In
Display: Color LCD, 2560 x 1600 Retina, Main, MirrorOff, Online
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1867 MHz, 0x80AD, 0x483943434E4E4E424C54414C41522D4E5544
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1867 MHz, 0x80AD, 0x483943434E4E4E424C54414C41522D4E5544
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x133), Broadcom BCM43xx 1.0 (7.77.111.1 AirPortDriverBrcmNIC-1710.3)
AirPort:
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD SM0128G, 121.33 GB
USB Device: USB30Bus
USB Device: Bluetooth USB Host Controller
USB Device: USB 2.0 Camera
Thunderbolt Bus: MacBook Pro, Apple Inc., 27.1
LightBurn should not crash, so thank you for bringing this to our attention. We will dig in and provide feedback after review.
I’m not really a Mac user but someone told me that it looks Camera related.
The suggestion I received was to turn off the camera and see if it becomes more stable.
Please let me know if this helps.
I definitely think that could be the culprit as it started after I added the camera.
